I would like to use one output as my N2O controller. I would like to use it as WOT switch, pressure safety switch and RPM switch. I think the below is how I would do this, but some feedback would be great. Not sure if the RPMs will work like this. Maybe there is another way to do this. Do I need to input units? Is the fuel pressure sensor reading PSI? Is PID 17 reading %? How do I know what the readings are? I would also like to see if I can add AFR into the equation for more safety.
Enable Trigger
[PID.17]>98+[SENS.70]>3500+[SENS.34]>52
Disable Trigger
[PID.17]<97+[SENS.70]<6500+[SENS.34]<50
TIA
