Results 1 to 6 of 6
Thread: VE Table Editing
    Advanced Tuner Screamn03's Avatar
    Feb 2004
    Vacaville, CA
    832
    VE Table Editing
    I would figure since this motor has a cam and other airflow enhancing modifications done to it that the VE table is the first table that should be edited. Am I correct on this? If I am anyone have a good procedure for this?
    BTW-stock MAF is on the car right now in case you looked at my sig
    -Michael Rudolph-
    2003 Redfire Cobra
    Eaton Powered to a:
    11.301 @ 129 1.68 60' MT DRs
    11.85 @ 124 1.90 60' street tires
    Nov 2002
    Central Florida
    2,503
    Re: VE Table Editing
    From what I've seen it's pretty much cut-and-try, and
    most people just adjust as little as possible (down at
    the low end, where VE value fidelity affects idle quality).
    I believe you can use the MAF (if you trust its output)
    to judge the speed-density valculation and VE; there
    is a MAF = VE*MAP*RPM kind of equation that you'd
    have to get scaled right for the units you can log, and
    maybe use Excel to then look at 1-MAF/(VEMAPRPM) as
    an error % or something like that. All falls apart once
    you get away from the stocker, but as long as you have
    that and are away from its lower and upper accuracy
    limits that should be good. I think for the most part the
    cam overlap only affects VE at the low end, shorty
    headers are probably not affecting much except maybe
    at the extreme top end though long tubes will extract
    further down the band.
    Feb 2004
    Vacaville, CA
    832
    In short summary I ended up finding this formula to work the best because it's simple and I understand it:
    %VE = (MAF * (IAT + 273.15) / (DISPL * RPM * MAP)) * 212544
    I believe these to be the correct units:
    MAF=grams/second
    IAT=*C
    DISP=One Cylinder in CU/IN
    MAP=KPA
    I've been searching on LS1Tech about this and started this thread that is a summary of the information that I found:
    http://www.ls1tech.com/forums/showthread.php?t=156935
    :huh2: :huh2: :huh2: :huh2:
    -Michael Rudolph-
    2003 Redfire Cobra
    Eaton Powered to a:
    you need to understand what VE is guys. VE is just the amount (volume) of air you are getting into each cylinder versus the amount you could theoretically get in there under ideal conditions. Hence the name *volumetric* efficiency.
    So you get:
    VE = CylAir Actual / CylAir Ideal
    if you have a MAF and you trust its measurement then to work out the amount of air going into each cylinder on average for a V8 engine is just:
    CylAir Actual = MAF(gm/sec) *15 / RPM
    now to work out CylAir Ideal you need to go look at the gas equations PV = nRT and plug in the atmospheric (barometric) pressure for P, the cylinder volume for V, the Air Temperature (in Kelvin) for T and the values of R etc...
    you get something like:
    CylAir Ideal = (BARO * (Displ/8) * 28.96) / (8.3145 * (IAT + 273))
    then divide the two values to get the VE or:
    VE = (MAF(gm/sec) *15 / RPM) / ((BARO * (Displ/8) * 28.96) / (8.3145 * (IAT + 273)))
    which reduces to your equation once you adjust for units etc.
    If you put MAP in instead of BARO you will get the theoretical airmass at the current throttle position (ie. you are removing the effects of intake tract loss). True VE is compared against BARO.
    I count sheep in hex...
    Nov 2002
    Central Florida
    2,503
    But the VE as used in our engine controls is
    the MAP referenced one, yes?
    Quote Originally Posted by jimmyblue
    well, just remember that the VE table is there to tell the PCM how much air is in each cylinder at the current MAP/RPM when the MAF is not there. It's replacing the MAF measured part of the equation (ie. the actual CylAir).
