I'm pretty sure that I've got the shift speed, shift property, auto TCC, and torque management tabs figured out. I was going to dig into the General Pressure tab but there's no help file info on this section so I thought I'd post to see what might be out there.
It appears as though my stock tune has the Adapt counters inactive and/or zero'd out (enable speed of 256 mph). The pressure control areas seem to have data in them, but I'm not sure exactly what they do. My guess is that I don't even need to mess with them with an almost stock truck, but I'd still like to understand what they do.
Truck has 1 size larger tires which I've measured to be 30.25". Other than that, stock when it comes to drivetrain. It does see some towing, but not often and not usually more than 2500 lbs.
Stock tune and my in-progress tune can be found below.
Thanks ahead of time for any help!
