I got another 97 GTP recently. The previous owner had it for a few years and never did anything to it other than have the transmission replaced, he knew it had a cold air intake and cat back exhaust, but he wasn't a GTP enthusiast, just used it as a DD. After driving it the first time I noticed it felt much faster than my other DD GTP that went 14.0-14.2. So the first thing I do is check the pulley out, sure enough, its got a 3.4 pulley on it, the cai, the catback exhaust, but other than that it looks stock, still has the u-bend.
So I read the tune thats on it and notice for one thing, that the injector flow rate vs kPa is all set to 38.28 across the board. Thats nothing like my other stock GTP files. I went ahead and left it, just did the basic tunning items like neg torque management, and whatnot. I then took it out to log things and noticed that it was running 85% duty cycle on the injectors, and the MAF was showing 36lb/min of air, it was also peaking at nearly 11 psi of boost yet was running stock high octane tables with minimal KR. The LTFTs never got worse than 1% and STFTS were within 5-7%, O2s were pretty solid 910-920 mV at WOT.
Something just doesn't seem quite right here. Its not that modded, 3.4 pulley, cai, and cat back yet the numbers indicate that its making over 300 horsepower?? As I am typing this out it almost seems possible if it has smaller injectors than stock, yet has been tuned around them. Does something seem strange to anyone else?
