I've been using DHP for nearly two years now and for obvious reasons, I now have HPT.
From what a friend of mine who tunes LS1's with HPT, the smoothness of the table is very important and I'm assuming because of the smoothing tools in the histograms, its important.
I'll use the VE table as an example - with DHP, I'd scan my trims etc..and use Eddies table modifier program, it would find the target cells that were causing the + or - condition in the trims and adjust accordingly. This would lead to a "bumpy" tables, but would result in good trims up to I went into PE at 40% throttle. From the help in HPT, a rough VE table is "bad."
Is this acceptable or optimal how it is done in HPT? I've still got to go read and learn how to import the scans and figure out how to make changes accordingly in HPT but I am just curious.
