Results 1 to 5 of 5
Thread: E38 - Short Term Fuel Trims keep turning on
    Nov 2007
    Minnesota
    555
    Tuning my MAF today and noticed the scanner keeps showing STFTs running even though I have the enable temp set to 284 for ST and 284 for LT. I have to manually use the scanner controls to turn trims off. Anyone else have this problem? Not sure if it is beta related or what but I've tuned many cars and never encountered this.
    2012 Chevy Cruze A6 1LT RS
    Formerly - 2004 GTO, 2002 Z28, 2007 Colorado, 2008 Silverado
    Mar 2011
    384
    post tune?
    My setup is a 356ci with a 260/268 (212/218 at .050 lift) duration cam with aluminium corvette heads and flat top pistons running 11.3 comp. ratio. with tuned port injection and vortec crank pick up and dizzy running a 411 pcm and 60lb bosch injectors, 1.6 ratio roller rockers. For transmission its a 4l65e built with the monster in a box mega ss kit. All in a 92 chevy ext cab 4x4 pickup with a 98 cab now installed with a third door! running only e85
    Nov 2007
    Minnesota
    555
    Here you go, mate.
    28,266
    I believe You need to set the o2 readiness table to the max.
    Nov 2007
    Minnesota
    555
    Thanks, Bill. I will give that a shot.
