Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Help on Wideband
    Help on Wideband
    I am wanting to get a Wideband, I did some searches and still have no idea on what to get.
    What I want is to be able to have an actual digital gage on my pillar plus be able to hook it up to HPTuners to log/tune
    How do you actually tune with a wideband? what i have done so far is update my ve table by using trims for part throttle in the closed loop (AFR multiplyer = 1) portion of the table. How do you actually use the wideband to tune
    what is real time tuning (RTT) how do you get it
    2002 Camaro Z28
    236/236/0.590"/0.590"/112 lsa cam
    Longtube Headers, True Dual w/ X Pipe
    Air Lid, Filter, Ported Maf End, Bellows Hose
    Tuner BlackGS's Avatar
    Aug 2007
    Central Jersey
    170
    I have the PLX SM-AFR unit with the DM-100 gauge. I only have one forward stock narrowband O2 sensor, so I replaced my stock sensor with the wideband sensor. The SM-AFR unit will simulate a stock narrowband signal to the PCM. The SM-AFR also includes output so you can wire it into the HPT EIO interface.
    After you install the WB, you will scan using the WB input which will give you a much more accurate AFR. From there, you can fine tune. In my case I adjust MAF and PE values based on the AFR I see in various ranges. If you have access to a dyno you can figure out the best AFR for your setup and always try to tune around that. Without the wideband you are just guessing at optimal AFR.
    The DM-100 gauge is sweet. It has various display modes and can be customized to display any background pic you want. The really nice advantage of the DM-100 is that you can program warnings. For instance, I can set it to warn me if my boost is over xx psi and AFR is more than 12.5, or something like that. It will actually flash a big warning message, and I can back off the throttle before I blow something up. Check out the PLX website for a demo video.
    2000 Regal GS | Twin-Charged T72 | HPT Pro + PLX Wideband | 12.55 @ 110 on 15psi | Now running 20psi on E85!
    1998 5.9L Durango | Powerdyne supercharger @6psi | Mesa Headers | Gibson Cat-back | 1.7 RR's | Tuned PCM | Ported Heads | Custom TB & Intake | Custom fuel rails | Rebuild coming soon...
    Let me get this straight, I can just swap a stock narrowband for the wideband and the car will still operate normally as if it was still the stock narrowband sensor. how do you hook it up to your car so it will do the fueling adjustments, does it have a harness to hook right up to the car, as well as being able to run a gauge and hook up to HPTuners???
    2002 Camaro Z28
    Aug 2007
    Central Jersey
    170
    Quote Originally Posted by ChrisV 02 - Z28
    You can't just swap any wideband. There must be a signal converter. Narrowband signal is 0-1v and wideband is 0-5v. PLX gives you this signal converter in their setup. Read this: http://www.plxdevices.com/AppNotes/PLXApp004.pdf
    It is not completely plug-n-play. To install the PLX WB, you remove your narrowband sensor from the exhaust, and install the WB in the same bung. There are usually four wires that run from the PCM to the narrowband: 1) Signal, 2) Ground, 3) Heater power, 4) Heater Ground. Since the WB heater does not get its signal from the PCM, you have to fool the PCM into thinking the sensor heater is working ok. This is done by installing a 20ohm resistor between the heater power and heater ground. Then you run the stock signal and ground wires from the PCM into the PLX converter. The converter also has output connections so you can run wires from the converter to an HPT Pro interface. (If you don't have the HPT Pro, there are other ways to get the wideband signal into HPT, but you have to know a lot more about your specific PCM wiring.)
    The PLX is fairly easy to install, except you have to run wires everywhere and figure out where to mount the resistor(s). Since I have my EGR removed, I used that bolt hole on the block to mount my resistors on a small piece of metal. I used two 10ohm resistors instead of one 20ohm.
    Fueling adjustments are done by the PCM, not the O2 sensor. The sensor just returns a value indicating to the PCM how rich or lean the fuel mixture is in the exhaust. The PLX converter will take the WB AFR reading and convert it back to narrowband for the PCM. For example, if your exhaust AFR is 11.8, the PLX will convert that to something like 930mv and send that to the PCM for fueling calculations.
    Nov 2005
    Houston, TX
    3,968
    I would choose a WB that has the ability to do free air calibration like the Innovate LC-1 or NGK AFX.
    Bill Winters
    Out of the LSx tuning game
    Aug 2007
    Central Jersey
    170
    Quote Originally Posted by 5_Liter_Eater
    That issue comes up a lot about PLX.
    From the PLX website:
    "Other products on the market which require calibration use an unconventional control technology not recomended by Bosch. This is designed to reduce manufacturing costs and places the burdon of having the user calibrate the sensor.
    PLX devices widebands are all meticulously calibrated from the factory, and gives you "plug and play" usability."
    "The LC-1 and the LM-1 both use an unconventional method of controlling the o2 sensor which is not the recomended control method according to the Bosch Datasheets. The PLX wideband control circuirty was designed according to the specific requirments directly from the Bosch datasheets which does not need any manual calibration.
    These Bosch sensors are utilized in OEM Porsch, VW, and several other european manufacturers directly. The driver never has to manually calibrate the wideband sensor throughout the entire duration of the ownership of the vehicle.
    In short, proper design of a wideband controller requires the Bosch sensor to be plugged in and used, without ever having to manually recalibrate the wideband controller."
    More info:
    http://www.plxdevices.com/AppNotes/P...Technology.pdf
    Nov 2005
    Houston, TX
    3,968
    The OEM's using the sensor are not using it in the fashion we are. It can be off by half a point and it will not affect their tune. Technically I agree with it but I think it's a nice feature to have when you start doubting your WB. My dad has an LC-1 which uses the same Bosch 4.2 sensor which is supposed to be calibrated out of the box like the PLX and AEM and it changed over a point when he did the free air calibration.
    Bill Winters
    well i ordered the plx setup with the D5 gauge.
    i know there is a harness to hook the WB up to the sensor box, but is there a wire harness to hook up the analog feature to the stock narrowband o2 sensor wire (so i can replace the narrowband and not have to cut wires up) and hptuners box??? or do i just gotta splice wires
    also is the x pipe an ok place to put the wb in at?
    i am assuming once i get the wb hooked up to hptuners, what is the actual process of tuning the VE and MAF tables, be precise.
    I tuned the VE table at part throttle (where the a/f multiplier = 1 on the table) by using the feul trims and got my trims in the -2% to -3% range trhough except for idle, it is like -10% feul trim
    do i have to turn off ltft and stft to see the raw feuling a/f ratio via the wideband and correct the ve table until the wb o2 matches the nb 02 readings??
    how do you tune maf now, never messed with that
    2002 Camaro Z28
    Nov 2005
    Houston, TX
    3,968
    Read some of the stickies for WB tuning. It's basically the same as regular fuel trim tuning but you don't have to worry about going into PE. You turn off the fuel trims and log the AFR error and change your VE and MAF tables based on that.
    There will be no harness to have one of the outputs sim the narrow band. You will need to splice it into the NB O2 harness. The x-pipe should be OK as long as it's ahead of the cats.
    Bill Winters
    I have no cats, the x pipe near the tail shaft of the tranny, is that too far back??
    2002 Camaro Z28
    Nov 2005
    Houston, TX
    3,968
    Not sure if it will pose a problem or not. Ideally it would be in the header collector, closer to the head.
    Bill Winters
    Aug 2007
    Central Jersey
    170
    I had an extension harness for my stock O2 wiring from when I first installed my headers. I just cut this and fabricated a couple connectors on the end of the cut wires.
    http://www.zzperformance.com/grand_p...=357&catid=108
    There is a recommended distance from the engine for the wideband sensor, but I can't remember the exact distance. You will get the info in the instructions, or check out the forums on PLX.
    I've seen a lot of people talk about calibrating the LC-1, and how it is required, but I haven't yet heard of anyone saying their PLX was not calibrated correctly. I know they have a series of tests you can run against the sensor to test for accuracy, one of which is to run it in open air, but I think that just checks that it is functioning properly. I've been using mine for a few months now in a daily driver, and trims have locked in perfectly. I run right on the edge of knock in WOT and have been able to dial in some good fueling and timing. I ran my PB at the track before the wideband, and I think now that I have a solid tune, I'm going to drop that at least a half second.
    Here is what I plan to do....need some help
    I will be replacing the stock NB sensor with the WB on a 2002 Camaro Z28.
    I plan on disabling the SES light for the stock heater and capping those wires off under the car. I am gonna hook the 1Volt analog output to the stock sensor harness under the car so it will still operate as if a stock sensor is there, then hook the 5Volt analog output to the PCM EGR pin so i can log through that sensor using HPTuners.
    My question is, Do I need to hook up the capacitor anywhere in my setup since I am not using a 3rd party scanner directly hooked to the 5volt analog line, like I said the analog lines will both be connected back to the car o2 sensor harness/pcm pin. I will be logging the WB through the EGR sensor from OBDII port
    Also will it matter where I pull my 12 volt ignition power and place my ground at with this setup, I seen on here it says to get power/ground as close to the pcm as possible, but dont understand why???
    Any help or feedback is greatly appreciated
    Also I plan on using the IGN auxillary hookup on the fuse box on the left side of the dash, do i need to add an inline fuse holder or is it already fused?
    2002 Camaro Z28
    Aug 2007
    Central Jersey
    170
    From PLX instructions:
    "Install the noise filtering capacitor across Chassis GND and O2 Signal Input as close as possible to the ECU. This eliminates unwanted electrical noise and increases close loop ECU performance."
    If you don't install the capacitor on the O2 signal, you will throw a code for insufficient signal count. The PCM expects the O2 sensor to swing from rich to lean a number of times in a set period to verify it is working correctly. I tried not installing the capacitor, and I got the DTC.
    Since you are using the EGR to send the signal to your scanner, I don't think you need to use the capacitor, but I'm not positive. Might want to ask over on the PLX forums.
    I'm not positive why you have to get power so close to the PCM. Something to do with seeing the same reference ground.
    yes but which O2 signal wire... the narrow or wide band?
    2002 Camaro Z28
    Aug 2007
    Central Jersey
    170
    Put the capacitor on the stock narrowband wire that goes back to the PCM.
    I just got an email from plx and in it they said "install 2 10ohm 20W resistor in between heater + and - to fool ECU, or OBDII cars 1k ohm 10W"
    in this post it said to use 20 ohm not 1k ohm??????
    2002 Camaro Z28
    Aug 2007
    Central Jersey
    170
    I don't know about the 1K ohm resistor. I used exactly what they said in the instructions:
    "*You may use two 10 Ohm 10 Watt resistors connected in series as an alternate solution. Radio Shack part#271-132."
    I got the exact part at Radio Shack and installed them as described. I've never had a DTC for the O2 heater, so I'm guessing it works fine.
    Can I just turn off the DTC code for the passenger side O2 sensor heater (since that is the one i am replacing with WB), instead of using a resistor??? or will that through the pcm into a different mode or something???
    if not how hot does the resistor get, just trying to figure how to secure it and with what to secure it with?
    2002 Camaro Z28
    Aug 2007
    Central Jersey
    170
    I thought about just disabling the DTC as well. I looked through the service manual and couldn't find anything that said the failed heater code would cause any problems. But then I was in Radio Shack and saw the resistors, and they were only a couple bucks, so I picked them up.
    The resistors are ceramic blocks with wires out each end. I fabricated a small metal square with a hole in the center, and then epoxied the resistors onto each side of the metal square. I soldered one end of the resistor leads to each other and the other ends ran to the heater wires. I mounted the metal square onto the engine block in the spot where the EGR used to be (mine is removed because of intercooler). Since this spot in the engine is right next to the header pipe crossover, I figured heat would not be a problem.
