Results 1 to 8 of 8
Thread: Idle-Airflow.cfg histogram
    Advanced Tuner Pro Street's Avatar
    806
    244
    After logging do you copy and paste the log into the BRA table?
    2018 GMC Denali A8 6.2L
    2016 CTS-V
    2016 C7 Z06 A8
    2016 C7 Z06/Z07 A8 vert
    2015 Chevy SS 6.2 LS3 A6
    1996 Impala SS LT1 CAI
    1995 Chevy 1500 5.3 CAI Z06 cam
    1957 Chevy vert
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    depends what you are logging. If you are logging the idle trims, you need to add.
    Sulski Performance Tuning
    806
    244
    I am using Russ K idle-airflow.cfg
    2016 CTS-V
    2016 C7 Z06 A8
    1957 Chevy vert
    806
    244
    Help!
    2016 CTS-V
    2016 C7 Z06 A8
    1957 Chevy vert
    If it's Russ k 's then u just copy paste the numbers into ur RAF ( Base Running Airflow )
    806
    244
    Thumbs up
    Thanks!
    2016 CTS-V
    2016 C7 Z06 A8
    1957 Chevy vert
    Bringing this back up, the data from the base Idle airflow histogram, do you copy and paste it into both the p/n and gear rows or just one of the rows?
    Also do you add the data collected for just paste the info in then intropolate?
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    If an auto trans, you need to do 2 separate scans. One in gear, and another scan in park. Then paste the in gear and park histogram in the matching RAF rows. Then compare the differences to the stock tune, make the differences the same for the temp cells you didn't collect data. And make sure that the units of the histogram & editor match.
    Russ Kemp
