I started tuning my buddies '07 Silverado, and want to see if there is more that I can do.
I started off by making sure to set the Engine TqMngmt to as little as possible, and then I set the tranny Tqmgt to 50% ( I read that is the most you want to do).
I raised timing by 4*, and leaned out the PE, and removed the PE delay.
Then I messed around with the tranny and set the Tow/Haul mode to function like a performance shift by increasing shift pressure and raising the shift rpm and speed.
I was wondering what else I could do to wake the truck up tune wise. It's a 07 4.8L New Bodystyle Work Truck with the A4. And it does not have the 3.73 gears.
I notice when you floor it from a stop the thing is pig slow until you get out of first gear. Can I make it more responsive down low in first gear somehow?
