Results 1 to 10 of 10
Thread: logging VE wb afr, VE afr error
    histograms don't go past 2800rpm.
    any particular reason why?
    i just installed my plx, and did some logging with the new wb with my HPT.
    the other histograms cover all the rpm i hit, but the above mentioned do not.
    the install went well. i tested it before i did the runs, and all was fine.
    thanks in advance.
    PS: oh! right clicked on the main table, insert, wideband, Plx. it seemed fine when i tested it.
    28,273
    Please post your .hpl & cooresponding .cfg file, without these things its impossible to help.
    thanks! and sorry!
    here is the last log, short, but a log.
    and the config file.
    again, thanks!
    28,273
    Quote Originally Posted by jegten
    thanks! and sorry!
    again, thanks!
    You have a cell count filter of 30, unless you have 30 in a cell it won't show.
    should i go for a much smaller number?
    i had 0 there before i did the run.
    thanks!
    man!
    that was easy!
    thank, Bill! as always!
    but, since i am doing the afr error, i should probably have some count to be able to use a nice average, right?
    28,273
    I wouldn't change my cell count if I were you, what I would do, however, is lower my bytes used to 24 or less so I get 10fps hits.
    Currently your logging 31 bytes of data and only getting 5fps hits meaning 1/2 as much data is being logged in the same amount of time as a person only logging 24 bytes.
    thanks!
    i will do that. actually, how do i change that? i can't seem to find how to change. sorry!
    also, what afr do i want to be commanded when logging?
    right now i have 14.68 hi res.
    28,273
    http://www.hptuners.com/forum/showthread.php?t=15989
    Changing the cell count is done here where it says cell hits required
    thanks, bill!
    i will delete my lo res pid and other ones, so that i can get the bytes needed.
    thanks for the screen shot. you had already helped me to figure out where that was earlier. thanks!
    i will have to go through the guide again, since i am commanding a 14.68 afr for transition. that's what i thought i read, putting 1s across that table open loop eq ratio.
    again, thanks!
