As I posted in another thread, closed loop can be a problem with a bigger cam...
If we could etell the PCM to go into open lood at idle, we could adjust the fueling without having the PCM compensate for what it thinks is a lean condition.With the bigger cam, it's going to idle rich especially when in closed loop. The O2 sensor monitors oxygen level in the exhaust (duh!). With a bigger can (big enough for a rough idle), you will have cylinders that do not fire at lower RPM (Idle). This pushes raw fuel (HC's) and Oxygen (since we didn't burn the fuel, we still have almost 14.7 parts of O2) past the O2 sensor. The biggest problem here is the PCM. The O2 sensor will tell the PCM the engine is running lean (not enough fuel to burn all of the O2), and the PCM adds MORE fuel.
Thanks for any advise on this.
