Results 1 to 11 of 11
Thread: 05 Mustang tuning help- spark advance & retard Scaning
    Dec 2005
    KSA
    46
    Hi,
    While scanning 05 Mustnag, the histogram shows nothing no reading, how to view the spark advance & retard readings.
    How to make the configureation to view the sparks.
    I need your help in this matter.
    High Way Garage
    Location Saudi Arabia - Jeddah
    Phone : 966 504 655 105
    Custom Tuner:
    GM - Ford - Chrysler - Dodge - Jeep- All Europian Cars + Ducati Bikes
    HP Tuners
    SCT Dealer
    Diablosport Dealer
    Sniper Delta Force Dealer
    Viezu Dealer
    Alien Tech Dealer
    Dynojet 224xlc dyno soon
    Custom Tuning via Email Available
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    You need to customize the histogram
    This should help get you going on the right foot http://www.hptuners.com/help/demos/customhisto.swf
    Dec 2005
    KSA
    46
    I tried to make the configration for the timing in the scanner, my aim is to show the timing values based on rpm and manifold pressure, after i have make all the setting in the histograms it still show NOTHING. (off course i double check that all the parameters needed are looged ).
    I have followed the link above it was helpful, but the histogram does not show any values after you set the configration when you are working with FORDS.
    This a scan from 05 mustang take a look at the histograms.
    High Way Garage
    Custom Tuner:
    HP Tuners
    SCT Dealer
    Diablosport Dealer
    Viezu Dealer
    Alien Tech Dealer
    HP Tuners Support
    (foff667)
    28,268
    Its because the definition doesn't appear to be supported yet. I can only assume you've read the file & sent it to support to be added.
    -Bill
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    The spark timing is referenced to load %, not map. Try logging the Calculated Load [SAE] (%) pid.
    Looks like the spark retard pid is not supported.
    I see that the Mass Airflow Voltage pid is not supported. As it will be required for tuning the Maf.
    Russ Kemp
    HP Tuners Support
    (foff667)
    28,268
    Quote Originally Posted by Russ K
    Russ Kemp
    If the definition file for the editor has not been added it means the definition file for the scanner has not been added either which is why you'd only get generic pid's while scanning. Once we get the definition file added you'll see dozens & in some cases hundreds of extra parameters available to scan.
    -Bill
    Tuner in Training Quasimotor's Avatar
    Oct 2007
    Tucson, Az
    29
    Talking
    Quote Originally Posted by Bill@HPTuners
    -Bill
    Bill,
    How long until we have definitions for the MAF voltage and Knock Pids? I am too trying to tune a late model, but with a supercharger. Without those pids I am stuck trying to listen for detonation, when I should be able to log it.
    Jim
    HP Tuners Support
    (foff667)
    28,268
    Quote Originally Posted by Quasimotor
    Bill,
    Jim
    You must send us the .hpt file you read off of the pcm & we will add it as quickly as possible, we currently only have 4 or 5 ford definition files in que to be completed, if you haven't sent in the .hpt file it won't get done until someone does for that particular calibration.
    May 2006
    Langhorne, Pa
    102
    I assume to the support address, Bill?
    2007 Mustang GT
    266rwhp 276rwftlb's. 13.6@104 stock.
    Adding a bunch of goodies and shooting for mid 12's.
    HP Tuners Support
    (foff667)
    28,268
    yupperz
    Oct 2007
    Tucson, Az
    29
    Talking
    Bill,
    I sent the file today.
    Thanks for the help!
    Jim
    2006 Chevy HHR 2.4L W/M62 Eaton From a Cobalt.
    60 Lb Siemens injectors
    2.7 inch pulley
    Upgraded Aftercooler plate
    Ion MAF with 3 inch tube
    2.5 bar LSJ MAP
    obx header
    trying to tune for e-85
