Results 1 to 6 of 6
Thread: 98 Yukon set base timing (replaced distributor)
    Oct 2007
    1
    When replacing the distributor, the cheap manual says to check "Cam Retard" for +2/-2 to set the base timing. I am looking for the OBD2 command to read and display that value (and what is the conversion if any)???
    Scot
    Aug 2007
    Topeka KS
    51
    this is what i requested to be added to the scanner, a correlation checker so you can set the distributor....same problem with my 98 4.3
    Steve(n)
    Nightmare
    Jan 2015
    McCurtain County
    5
    I emailed tech support, I'm just very surprised that in 7 years this hasn't been addressed?
    Oct 2014
    SE KANSAS
    11
    I'm running into the same thing on a 98 5.7. Wondering if if the "Cam Offset %" is perhaps the PID we need to use, however I have not been able prove/disprove this yet. Any thoughts on this, or am I gonna have to go borrow a Snap-On to set my timing?
    I must be shorter than I think, because it seems I am CONSTANTLY get'n in over my head!
    Builds:
    55 Bel Air Sedan - 5.3, 4L60, 3.73 Posi
    72 K5 Blazer - 5.3, 4L60, Passenger Drop 241C
    85 K10 Truck - 98-Vortec 350, 4L60, Passenger Drop 241C
    Coming Soon : 68 Chevelle Convertible to get 5.3/4L60
    Pics will be available IF I ever get around to it!!!
    Jul 2015
    21
    Any chance this can be added? Need to set timing on a 98 vortec 7.4 motor after replacing the distributor...
