Results 1 to 3 of 3
Thread: Wideband install questions
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    I have been in possesion of my LC-1 for about 2 months so far, and haven't been able to proceed with the install because of personal and technical reasons. I have resolved my personal issue, but still need a bit of help in the technical.
    At first I wanted to install the LC-1 into one of the existing Bungs, wire up the NB to the existing NB wiring and the WB to the EGR (have a 2004 C5) and run that way full time. Now I am not sure I want to permanantly install it because I may want to go from car to car.
    So here is my question, do I have to have the Pro MVPI to hook up to the Laptop while I am scanning with HPTuners? Is there away to tie the LC-1 into the HPTuners suit, via the Laptop, without the Pro version or the EGR?
    If I temporarily remove one of the stock NB Sensors and replace it with my WB will the PCM operate normally (assume I would have to disable that O2 sensors DTC) with the one O2 or would it drop immediately into open loop?
    Thanks for your time
    [email protected]
    Tuner killer_bluebird's Avatar
    Aug 2006
    North Olmsted, OH
    63
    Here is how to wire it with the Enhanced IO:
    http://www.ls1tech.com/forums/showthread.php?t=419524
    And here is how to wire it without go to post:
    http://www.ls1tech.com/forums/showthread.php?t=496625
    http://www.ls1tech.com/forums/showpo...4&postcount=58 (this is what I did)
    2000 NBM Camaro Z28
    Mods:
    SLP Lid & K&N, AHR Headers + 3" catted Y and Mangaflow, !EGR, !AIR, BMR CM STB, ST Front 35mm and Hellwig Adj. Rear 22mm Swaybar, Adj. Rod/Rod PHB, Koni SA's, Ground Control Springs & Adj. Ride height, and HPTuners.
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    moving this to the forum for questions like this...
    Sulski Performance Tuning
