I have been in possesion of my LC-1 for about 2 months so far, and haven't been able to proceed with the install because of personal and technical reasons. I have resolved my personal issue, but still need a bit of help in the technical.
At first I wanted to install the LC-1 into one of the existing Bungs, wire up the NB to the existing NB wiring and the WB to the EGR (have a 2004 C5) and run that way full time. Now I am not sure I want to permanantly install it because I may want to go from car to car.
So here is my question, do I have to have the Pro MVPI to hook up to the Laptop while I am scanning with HPTuners? Is there away to tie the LC-1 into the HPTuners suit, via the Laptop, without the Pro version or the EGR?
If I temporarily remove one of the stock NB Sensors and replace it with my WB will the PCM operate normally (assume I would have to disable that O2 sensors DTC) with the one O2 or would it drop immediately into open loop?
Thanks for your time
