Results 1 to 14 of 14
Thread: hpt to bin files, newb
    Aug 2007
    1
    After editing my stock tune and save to rewrite, it converts the bin file to an hpt file and won't let me use it. When I rename the file and try to write with it, I get an error message saying it's outside the size parameters, although it's about the same size as the original bin.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    .bin is raw format. We convert it to a proprietary format which allows us to store extra information ie history, comments, etc. it also compresses the file size which with the newer pcm's the files are very large so this helps in file size. There is no way to change back to .bin format from .hpt format.
    Sep 2002
    Chicago, IL
    6,395
    Are you editing with vcm editor 2.x and trying to flash with vcm flasher 1.x?
    In vcm editor 2.x, you flash directly in the program, there is no extra flash utility.
    We got this guy Not Sure, ...
    Thats just crazy talk? How can the software do a write entire flash with an HPT back into the PCM? Surely at some point the software must convert the HPT back to BIN.
    96 Grand Prix 3100 5-Speed Turbo
    T04E 50-Trim Internal WG @ 12psi, Intercooled | HM-282 5 Speed w/ EP LSD | Spec 3 Clutch w/ HTOB Port-Polish-Deshrouded Heads | Ported LIM | 36 lb/hr L67 Injectors @ 65 rail psi | Walbro 255 Pump | 2.5" Custom Exhaust w/ Dual Flowmaster 40s | 97 PCM w/ 2 Bar Map HPTuned | Synchronic BOV | 220A HO ALT | ARP Rods/Main/Pan/Studs/Flywheel Bolts
    Gauges: Wideband (data logging), EGT, Boost/Vac, Turbo Oil Press, Oil Temp
    Sep 2002
    Chicago, IL
    6,395
    This thread is 4 years old...
    HAHA, lol!
    Either way, I need to get my PCM's original bin file to alter MAP tables and other tables not present with HPT.
    Is there anyway I can have my HPT file sent to you guys, decompress it and send back the BIN version? The VIN is already paid for and changing it wouldn't make any sense.
    So what do you say? Can your engineers provide a bin file from an HPT file?
    Please
    Tuner in Training sreve's Avatar
    Jun 2008
    35
    If you know someone with DHP or TunerCats they can save a bin
    Tuner in Training charlieRobinson's Avatar
    Dec 2013
    27
    why is there no export to BIN functionality in the software?
    1999 Riviera L67 SII 3800
    XP HOT cam, 140# springs, Gen V swapped, 60# inj, E85
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    To protect the parameters that HPT maps.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Dec 2013
    27
    thank you for the reply. how else can I get my hpt file into tiny tuners to mod tables that arent available in hpt?
    Sep 2002
    Chicago, IL
    6,395
    What version of VCM Editor are you using, and what tables are missing?
    If you email your tune to support with the request, we can add the parameters so you can edit them.
    Advanced Tuner Road's Avatar
    Dec 2014
    Terrell Tx
    478
    Your not going to find any better support than this.
    Dec 2013
    27
    The newest version available for download 2.24
    I am tuning an L67 3800. Can you add this table to my tune file for me if I send it to you, Keith?
    I would like to have the ability to adjust crank fuel vs coolant temp as seen here:
    Sep 2002
    Chicago, IL
    6,395
    Please email support with that request and they can queue off the task to the appropriate engineer.
