Hello,
I have just tuned 2 2005 6.6 duramax by calibrating only the engine settings, I did not touch transmission and engine torque settings at all. The power gain is good but I got stiffer shiftings at high end rpms. Is it normal??? or would you suggest any softening touch on transmission parameters??? Please see the calibrated file attached, if needed. Regards, Murat
