Results 1 to 4 of 4
Thread: "other" inputs
    Aug 2007
    Topeka KS
    51
    "other" inputs
    What can the inputs on the pro module handle?
    Im wanting to get a sensor for my line pressure and log it through HP.
    Steve(n)
    Nightmare
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,272
    as long as its a 0-5v analog output you should be able to get it to work.
    Aug 2007
    Topeka KS
    51
    K, and my other question which relates to the emails ive sent you.
    Can I have, or can there be something put into the software in a future release to see where the distributor is set. On at least my truck, the distributor has to be set in a certain spot and must be within a few degrees to not trigger a CKP code. Most distributors are fixed so they only can be installed right where they are supposed to be. But with me running an aftermarket intake and distributor, I need to be able to see where I have it set, like you can with a tech 2
    Steve(n)
    Nightmare
    HP Tuners Support
    (foff667)
    28,272
    scanner/editor feature requests should go in the feature request section.
