Results 1 to 8 of 8
Thread: OBD II port issues
    Jul 2007
    5
    OBD II port issues
    I just picked up a scanmaster and cannot get my OBD II port to work with my car. The unit will power up and show the versions but goes dead after that. I just checked it in my buddies car and it works great! I pulled the panel down and removed the plug and found everything to be ok with it. Does anyone have any advice as to where to start the troubleshooting process? I know the port has power as it starts the unit fine. After talking with the Scanmaster on it they thought my port was bad. How can I verify this? Is there a pin on the computer that I can check continuity with the wires on the port? I'm guessing if I did that I should dis-connect my PCM first? Any help would be great! My biggest reason for posting this in this firum is that I will be purchasing HPtuners in the near future and would like ti make sure my port is unctioning correctly.
    Jul 2007
    5
    Anyone have any info at all??
    Does this scam master thing hook up to a laptop? Are you sure it is not getting power from the laptop? The reason I say that is most of the guys on this forum that claimed the port was fine but could not connect ended up finding a blown fuse that powers the port... its worth a check... Goodluck.
    Jul 2007
    5
    No laptop! It's just a scan/display tool.
    Oct 2007
    1
    Does the cigarette lighter work? If it doesnt, you have a blown fuse. Had that happen to me once before.
    Jan 2007
    30
    Grab a test light and check pin 16. Should be batt voltage, that's what powers up most adapters. If not start checking fuses.
    Refering to aldl pins-
    \ ---------16/
    John
    Sep 2002
    Chicago, IL
    6,395
    lol this post is three months old.
    We got this guy Not Sure, ...
    Jan 2007
    30
    oops, didn't look at all the dates-
    John-
