Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Thread: CODE P0315 - Can HPT Clear this?
  1. #21
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,265
    Yeah you need to control rpm & iac for the cylinder balance to highlight I believe, the procedure is in the help file I believe.
    Glad to hear CASE LEARN WORKS lol.
  2. #22
    Feb 2007
    San Antonio, TX
    1,255
    Nobody contacted support about it
    Lol!
    Janky Monkey Tuning
    Call or PM for tuning solutions.
    Cell 210-954-4985
    Wrench turning provided by 2 Tightwads Racing.
    Tune your own? Start here ----> Open Editor ---> Hit F1...READ!
    READ SOME MORE (Thank username 69Lt1bird): http://ls1tuningguide.com/
    Still lost? Consult a Pro!
    www.thetuningschool.com
    www.calibratedsuccess.com
    www.tunedbyfrost.com
  3. #23
    Tuner in Training siffert's Avatar
    Oct 2007
    43
    Quote Originally Posted by 8850 View Post
    Case Learn works with 2.22!
    Why are you using software thats nearly 2 years old? Try updating to 2.22 to see if that allows you to perform a case learn. All software updates are free.
    What can I say? Off to download 2.2.2 Thanks!
    07 Corvette C6 LS2 A6 - 11.74 @ 120.83
    Xcelerator CAI, Corsa Sports Catback, Kooks Headers/Hi Flo Cats, Ported Intake, The Bone Yard HP Tune, Drag Radials
  4. #24
    Nov 2008
    8
    This code came up on mine. I accidently installed the 2008 TBSS map and it popped on. I then installed the right 2007 TBSS map but it would not clear. I will give the steps a shot tomorrow. Thanks for posting the fix.
  5. #25
    May 2013
    19
    yess you help me too
  6. #26
    Jan 2016
    bellefontaine, ohio
    15
    ok i got it... had to start click relearn button then rev right away and it worked...
    using 3.0
    Ill try to clear this up for those having trouble...
    set park brake,
    push and hold brake until you are completely done,start vehicle,
    click ( crank learn) fairly quickly accelerate till you hit the cut off, let off throttle once it has come to an idle IF successful your mil will go off,
    click the OK button that told you to accell to cutoff,
    turn off ignition for atleast 15 second. restart and the mil should stay off
    you can now release the brake.. ( i also had to go into the diagnostic menu and clear the code from there on VCM Scanner but after that it should be fully reset.)
