Just curious if I can avoid the GM dealership!
2004 Avalanche: ICS Performance built 370 all hardened internals, MP122HH, 4L80E, E-Fans...all Stealth
http://s167.photobucket.com/albums/u138/dhpro/
DTC P0315, Crankshaft Position (CKP) System Variation Not Learned
open your scanner and connect it to your vehicle and follow these steps:
Special VCM Controls
<LI class=Spaced>CASE Learn: To use the CASE learn function please follow these steps:
- Put the vehicle into park (auto) or neutral (manual).
- Turn off all accessories and A/C.
- Apply the parking brake.
- Press the brake pedal. Keep the brake pedal depressed during the entire procedure.
- Press Begin.
- Gradually rev the vehicle to fuel cutoff (around 4000-5000 RPM's) over a period of about 4 seconds. When fuel cuts out, immediately release the throttle.
- Allow the engine to come back to an idle.
- Turn the ignition off for at least 15 seconds. This step is required for the VCM to store the newly learned configuration.
no need to clear this code, fix the problem.if you will not relearn crankshaft position System Variation you will not be able to detect misfire.
Originally Posted by vette_doc
Any way of doing crank relearn when engine is out and sitting on an engine dyno ?
custom harness and HPT and stock PCM on a LS7 2007 model ?
Rune
Nobody contacted support about it
07 Corvette C6 LS2 A6 - 11.74 @ 120.83
Xcelerator CAI, Corsa Sports Catback, Kooks Headers/Hi Flo Cats, Ported Intake, The Bone Yard HP Tune, Drag Radials
Make sure you follow the instructions in the help file as we made corrections to it after one of our employees purchased an LS2 equipped vehicle just so he could run this test to make sure it worked
- Turn the vehicle off.
- Press the brake pedal. Keep the brake pedal depressed during the entire procedure. REQUIRED for successful test completion
- Start the vehicle and let it idle.
- Press Begin.
I had the same "Not ready - ECT Low" message as 8850 in my 2007 LS2 A6
Corvette that I tried today. I followed the instructions above completely.
Using V2.2.0 Its not the car, its a problem with the HP Tuner software.
Case Learn works with 2.22!
Cylinder Balance didn't highlight but I don't have a procedure for it nor do I know what it's for.
