LC-1 set to replace NB o2 output hangs at 447
Howdy I am running my LC-1 as a NB o2 as well as a wideband but it is only puting out a constant reading of 447, the wide band outout seems to work. Does the lo ground on the 4 pin o2 harness need to be grounded to a common ground on the EIO? Any help would be great thanks. Right now I just have 2 wires on the o2 wiring harness the 12v power and the signal in. Any ideas would be great, I changed the speed the output through the LC-1 programer to 1/6 but this had no effect on the NB output.
Nevermind it looks like I do need to ground out the o2 harness at the EIO
