I'll give it shot Christian. How do I keep it from pulling fuel to maintain stoich?Originally Posted by miami993c297
ETP 215's 60cc
TR223/234 .636/.599 114lsa
Fast90/NW90TB
All bolt-ons -ewp
Running OLSD seems to be the best shortcut...Originally Posted by 02Z0h6
The easiest way would be starting to use the VCM Controls (I like play with it) and modify your AFR Control value under Fuel & Spark, pretty easy and straightforward...
I use it as an experiment tool that can be change in a second not stopping driving to understand and learn what the engine is comfortable with.
Regarding my conclusions I know if AFR is acting on my problem (low load bucking) and the engine reacting to fuel addition or fuel substraction in this zone in going from reach to lean...
That way of working was already described by Russ earlier...and if you cannot find a way to have your engine not having a nice combustion adjusting timing vs. fuel it is time to consider the Ignition System by itself or the Intake Peripheral System, I don't see the point of huge overlap with your camshaft design.
Waiting for your results
Christian
418Ci TEC Assembled/ ETP-FTI Prep/ FTI "Barbara Streisand" Cam 664 HP Pump Gas.
Losers can always explain why...as winners never explain how...
What makes a Top Performer Human is the mistake…What makes him the greatest is his ability to repair it
Thanks Christian. I'll try and play with it and see what happens. As you pointed out, my cam doesn't have much overlap (1*) and that's why I feel driveability can be better. If I had a 24X/24X on a 110 then maybe I could live with it. By today's standards my cam isn't very big.Originally Posted by miami993c297
ETP 215's 60cc
Fast90/NW90TB
All bolt-ons -ewp
Russ,Originally Posted by Russ K
Above where you talk aboutThe low map boundary should be ~5 kpa higher than your idle map (in gear for an A4), then the high map should be 80-85 kpa, and the mid map half way between.Where is the idle map that you are talking about? I am having a similar issue and wanna give your method a shot.
thanks
frank
These are the settings for my car.
Russ Kemp
The solution for me was dialing in the fuel. Use vcm controls to turn spark idle off. I have ltft off as well since I have a large cam with 283 duration and 624 lift with lobe separation of 112. Log data after the car is warm. Fuel trims reset and fuel trim learn off. Log stft. Run the rpms through all the load cells while at idle that are affected by surge and make sure to maintain each load for enough time that the stft log stabilizes. After logging take the stft table and multiply by percent in the VE table. Soon your stft will be smoothed and you can fine tune while driving.
