I have an 05 GTO that I want to go SD on, however, I am exceeding 2 bar, so I want to use a 2.5 or 3 bar sensor on the 2 bar tune and just fudge the numbers to make it work. I'd assume this is possible, but was hoping someone who has maybe done this can chime in and give some advice on getting this done. Also, is there a way to set the scanner up to read accurately up to my max PSI, even though the ECU only thinks it is getting 2 bar of pressure just so I can see what is going on? Lastly, once updated, is there a PID for a 2 bar map and histogram available (or how to set one up) that will let me log AFR vs. VE (boost map?) like there is now?
Lastly, is there any way to tune it so that the MAF handles part throttle and cruising conditions while the SD "takes over" at higher levels? Maybe with the MAF fail limits?
Thanks and sorry if I missed this somewhere already, go easy on the new guy .
Joe
