Results 1 to 18 of 18
Thread: Where does cranking advance come from?
    Nov 2002
    Central Florida
    2,503
    I see a fairly low (12.5 degree) advance during cranking
    followed by a jump-up to the main table values once I let
    go. Starting to think maybe I have overadvanced the low
    RPM and it's fighting itself, or something; the fuel and air
    seem to be not changing (now that they're tweaked and
    pegged open, respectively) and the RPM dive seems to
    have only spark to blame.
    I can't find a cranking advance table. Is it just hiding, or
    is it not available?
    Супер Модератор EC_Tune's Avatar
    Apr 2003
    Almost 2000 feet.
    7,876
    Might be pulling it off the Base or LO table. Check to see what airflow you are running during cranking and see if it corresponds to either table. Otherwise, I would say it's hiding.
    Always Support Our Troops!
    LS1 cranking spark is not in the editor, added to my To-do list
    I count sheep in hex...
    Apr 2003
    Almost 2000 feet.
    7,876
    Aha!
    Oct 2009
    229
    So do we have cranking spark tables yet ?
    Jan 2007
    12
    Looking for an update.
    Putting this back up at the top, do any of the betas have this feature yet? My stuff is commanding 11.5 degrees of advance at startup. and takes a couple of attempts to get started. Motor is a low compression blower setup with cold plugs. If I lock it @ 18 degrees, it lights right off.
    Senior Tuner Google's Avatar
    Sep 2010
    Saint Peters, Missouri
    1,303
    I do not see it.. but a fix is.. more timing = less airflow.. less timing = more airflow.. so if your not able to get enough timing to start the engine then add a little airflow and it should fire up better..
    We Can Fix Your Bricked PCM Or Your YYYYYY OS ID
    5BA8
    3,256
    Quote Originally Posted by Google View Post
    It's not always that simple. Especially in the LS2 cars. They pull the timing negative when warm. -5 degrees. Setting the cranking spark table to something in the positive teens really helps the cammed cars.
    PS, it is available for both LS1s and LS2s in the competitor's software. Sure would be nice to have it here........
    email=[email protected]
    Sep 2010
    1,303
    never had an issue with the ls2's and timing, idle, or airflow myself but good for others to know I guess..
    HPT staff will get around to it.. they always do.. I have my work arounds untill then.. not giving the other guys my money.. but have used it when customer supplys it and requests it used.. customers is always right..
    28,268
    There are also alot of tables we have that they don't
    Its all mainly a matter of time & manpower to get tables added.
    In all honestly Chris likely forgot about doing these adds as we recently did a round of LS1 adds for several new tables that were requested. Highly doubtful he wanted to make more work for himself by not adding these at that time
    If anyone needs this table for a specific operating system email support with your serial number & the .hpt file and I'll see what I can do.
    5BA8
    3,256
    It's not an idle issue, it's a startup issue. And while I don't want to get into a pissing contest, I can tell you that you can only put so much startup airflow in these cars. All the ETC cars, even the LS1s, if you get too much base airflow, or startup airflow, or a combination of both, they'll actually close the blade.
    I've run into several bigger cammed strokers, and blown strokers that the only fix was to raise to cranking spark table. Same for the E38 cars with big cams. LS7s and such. Fortunately, they have the cranking spark table available here.
    As for owning other software, you can't narrow your scope to just one software. There's too much stuff that's not available in one or the other, as Bill has mentioned. There's things that Tunercat can do that neither HPT of EFILive can do. You tune enough cars, you'll run into issues that can't be fixed by one, by can by another.
    5BA8
    3,256
    That wasn't a knock on the company or software. You know I use it way more than the other. You guys have been great about adding features and tables. I've asked for a few things, and alomst everything I've asked for you guys have added. The cranking spark would be a huge help. Esp in the E40s.
    Thanks agian Bill for all your help.
    28,268
    Chris has added the cranking spark table to all the 512kb LS1 pcm's in the newest beta, if you need access contact support with the subject line LS1 512kb cranking spark table and your serial number and I'll issue it to you.
    Dec 2005
    214
    Bingo
    28,268
    Quote Originally Posted by vortec View Post
    Bingo
    but we can sure try
    Cranking table added to all E40 operating systems http://www.hptuners.com/forum/showthread.php?t=32690
    Advanced Tuner MikeGyver's Avatar
    Feb 2006
    Suburban Chicago
    268
    Wowie, kazowie! I got the latest Beta to play with, to have something to do in this weather. I bumped the whole table by 1.5x, and now the truck starts like stock. I don't have much overlap in my cam, I wonder if the added timing is making up for poor idle tuning. Whatever, thanks for the new table.
    2000 GMC 2500 2-bar SD
    Stock LM7, LTs, TBSS intake manifold
    Aug 2009
    Calibrating
    3,373
    Ed or anyone else how are you modding this cranking spark table? I thought about adding 10-15 % to see if it helps my starts any. I have increased cranking fuel, but this may be the ticket here.
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    May 2010
    39
    How can you not have a cranking timing table??????????? Glad you guys dont build engines... might find one with missing pistons.
