Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Scanner won't read 3bar
    I have a 3bar tune in my car and when we scan it the scanner only goes up to 1bar. I attached my file below.
    Sep 2002
    Chicago, IL
    6,397
    Post your scan as well.
    We got this guy Not Sure, ...
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,285
    MAKE SURE you follow steps 18,19,20 as listed here http://www.hptuners.com/help/vcm_edi...ters_gm_os.htm
    18. (This step for 2bar and 3bar enhancement only)
    Open VCM Scanner and connect to the vehicle. Open the Table display (Scan -> Table Display). Right-click the "Manifold Air Pressure (SAE)" PID and select "Delete". This removes the existing 1 bar PID from the table, if you don't do this the histogram will not function correctly.
    19.(This step for 2bar and 3bar enhancement only)
    Right-click again on the table display cell and select "Insert", go to the Engine -> Airflow section and choose either the "Manifold Air Pressure - 2 bar" or "Manifold Air Pressure - 3 bar" PID, double-click to insert it into the table.
    20.(This step for 2bar and 3bar enhancement only)
    Save the new scanner configuration using File -> Save Config.
    these are often missed and 99% of the time is the issue
    when I right click and go to insert. It only shows Manifold Air Pressure. It does not show the 2 or 3bar options.
    here is my scan file.
    HP Tuners Support
    (foff667)
    28,285
    you need to do another log & follow the steps I posted...you can't alter a log you've already completed.
    I did exactly what you posted. I connected to the car. Went to display -> table. Then right clicked on the Manifold Air Pressure and deleted it. Then right clicked on that block hit insert. Went to Engine -> Air Flow -> and the 2 and 3bar are not listed. There is Manifold Air Pressure but doesnt not say 2 or 3bar.
    I posted the above scan b/c I was asked to in the first post. I did not try to do those steps to that log.
    HP Tuners Support
    (foff667)
    28,285
    did you click the connect button before trying to insert a pid?
    HP Tuners Support
    (foff667)
    28,285
    the only other thing I can think of is you didnt actually do a write entire with that hpt file that you posted above. Easiest way to check that would probably be to do a read entire on the pcm as it stands to see if it pulls out that same file with the extended ve table.
    HP Tuners Support
    (foff667)
    28,285
    oh and this might be a horribly stupid sounding question to you but for the record did you install a 3 bar map sensor?
    I went into the chart configuration and went to chart 2 and changed the max KPA from 105 to 315. Will this work or will it still read incorrect?
    yea I did.
    HP Tuners Support
    (foff667)
    28,285
    no it will not work.
    well I did the write entire and still dont have that option. Anything else you can think of? Or can I send you my config and you take a look at it?
    here is my config file with the changes on the max MAP value.
    HP Tuners Support
    (foff667)
    28,285
    your config file really does nothing to help us.
    a. I still would like for you to read the pcm to see what file is in it right now.
    b. I still would like to know if your running a 3 bar map sensor.
    yes I am running a 3bar map sensor. When I pull the file out of my computer it pulls out the same file as above.
    HP Tuners Support
    (foff667)
    28,285
    Im at a loss then man...I suggest emailing support with a link to this thread so they can bench test it to see what up...unfortunatly I don't have a way to test your file any further.
    -Bill
    Sep 2002
    Chicago, IL
    6,397
    Looks like we're misisng a piece on the scanner software for that 3bar OS. We'll have an update shortly for you.
    Sep 2002
    Chicago, IL
    6,397
    PM me your serial # please.
    You have a PM on the way, Keith.
