Dodge Avenger 2.0 2008 rev limiter and throttle closing
I have a 2008 Dodge Avenger with a built 2.0 (euro model gas, basically the same as the US 2.4 but smaller) engine. I would need to raise the rev limit to at least 7500 with this build. Stock fuel cut off was at 6700 rpm. Raising this to 7000 works, but something else is limiting the revs after that. For example if I lift to 7500, the limit still stays at 7000. What I observed logging, is that the throttle body closes completely at 7000. Also it starts gradually closing already at 6400. I think I have scaled every necessary table for higher rpm but no help. My tune may be horrible also in other ways too because I'm an amateur and just started tuning with this setup.
Could somebody point me in to a right direction with this, or is impossible to change rev limit higher than 7000 with HPTuners? Attached is the tune as it is at the moment.
