Results 1 to 3 of 3
Thread: 2013 6.2 6R80 shift Flare/drag
    Aug 2023
    I'm having an issue on my truck that is beyond my level of knowledge. When the transmission is under ~120 degrees I get a bad binding/dragging and long 4-5 shift. When its is above ~120 degrees it shifts perfectly normal. When I reset the adaptive memory it initially shifts 4-5 perfectly normal regardless of temp until it learns its way back to shifting terribly. It also has an occasional 3-4 flare when hot and shifts 3-4 perfect when cold, this is more minor. I recently changed the lead frame and fluid, everything looked fine inside the trans and the fluid and magnet looked about as expected for the mileage. I don't know if I am chasing a mechanical or tuning issue, perhaps one of you 6r80 experts could shed some light? I'm happy to log but not sure what parameters are the correct ones to watch.
    If it needs a rebuild that's fine but I don't want to go down that path just to have it do the same thing after. The fact that is is capable of great shifts under certain conditions makes me think it might be tuning related. The truck had a (questionable)tune already when I bought it. I have since been using HpTuners to adjust some of the things I didn't like(pinging while towing, timing was advance up to 12 degrees over stock!). The torque values now show low-no errors on logs. I have used the trans tuning tables from the existing aftermarket tune and also the stock tune for the truck and while it changes the behavior I think the root problem is still there. I have viewed some of the other 2013 F-150 files in the repository and see some pretty drastic differences on some of the transmission values but I'm not sure what they all mean. I am tempted to upload the stock 5.0 6r80 trans parameters just to see if it has an effect but don't want to cause further problems. Thanks for any help.
    Aug 2023
    SoCal
    484
    Post a log so that we can see what is actually going on when it is acting up. Be sure to include all the transmission parameters and to log both cold when it is acting up and warm once it feels fine.
    Robert Moreau
    TransGo
    May 2024
    Does someone pls point me to the parameter significance which I see in Forscan for TCM, below . Me too have some issue with 6r80, and unable to interpret the PID values and its significance . I do see the actual slip is different that slip desired in gears even on 3 or evn on 5th . When desired slip is 1020, does it mean actual can vary from 0 to 1020 ? , also the shift rpm drop and rise too have some variations.
    Attached few graph too
    GEAR_RAT 4.171 :1 Gear Ratio Commanded
    GEAR_OSC 1 Gear Command by Output State Control
    DTC TCM 0 Continuous Codes
    BARO 91.0 kPa Barometric pressure
    LOAD 23.92 % Calculated Load Value
    SELTESTDTC 0 Diagnostic Trouble Codes
    SHFT_DROP 1 1/min Shift RPM Drop in Input Shaft Speed Below Expected
    SHFT_FLRE 1 1/min Shift RPM Rise in Input Shaft Speed Above Expected
    TCC_F No Fault Torque Converter Clutch Fault
    TC_SLIPACT 42 1/min Torque converter slip actual
    TC_SLIPDSD 1020 1/min Torque converter slip desired
    TCC_RAT 0.950 :1 Transmission Slip Ratio
    RPM 887 1/min Engine Revolutions Per Minute
    4X4L Off 4x4 Low
    ADS Operational Active Diagnostic Session
    APP_D 0.00 % Accelerator Pedal Position D
    AXLE 3.729 :1 Axle Ratio
    CLR_DIST 18.0 km Distance since diagnostic trouble codes cleared
    ECT 90 ?C Engine coolant temperature
    HRSH_SHFT Off Firm Shift
    IAT 60 ?C Intake Air Temperature
    LINEDSD 534.0 kPa Line Pressure Control Desired
    MIL_DIST 0.0 km The distance travelled since the MIL was activated.
    OSS_F No Fault Output Shaft Speed Reliable
    OSS_SRC 208 1/min Actual Output Shaft Speed
    PCA 58.0 kPa Pressure Control Solenoid A
    PCA AMP 0.77 A Pressure Control Solenoid A
    PCA_F No Fault Pressure Control Solenoid A Status
    RLC Off Reverse Lamp Control
    RLC_F Yes Fault Reverse Control Lamp Status
    RUNTM 1888 s Time Since Engine Start
    SHFT_ID 1-2 Shift Identification of Shift PIDs Lag, Time, Flare and Drop.
    SHFT_LAG 335.94 ms Shift Time Elapsed From 10% to 90% of Complete
    SHFT_TIME 12.21 ms Shift Time Elapsed From Commanded to 10% Complete
    SHFT_TYP Man 2nd Shift Type
    SSA_AMP 1.00 A Shift Solenoid Pressure Control A
    SSB_AMP 0.81 A Shift Solenoid Pressure Control B
    SSC_AMP 0.14 A Shift Solenoid Pressure Control C
    SSD_AMP 0.95 A Shift Solenoid Pressure Control D
    SSLU_PRES 0.0 kPa Torque Converter Clutch Solenoid Pressure - Commanded
    SSPCA 550.0 kPa Shift Solenoid Pressure Control A
    SSPCA_F No Fault SSPCA Status
    SSPCB 26.0 kPa Shift Solenoid Pressure Control B
    SSPCB_F No Fault SSPCB Status
    SSPCC 14.0 kPa Shift Solenoid Pressure Control C
    SSPCC_F No Fault SSPCC Status
    SSPCD 0.0 kPa Shift Solenoid Pressure Control D
    SSPCD_F No Fault SSPCD Status
    SSPCE_F No Fault SSPCE Status
    SST_D HIGH Select Shift Transmission - Down Switch Input
    SST_U HIGH Select Shift Transmission - Up Switch Input
    TCCC 0.05 A Torque Converter Clutch Control solenoid
    TCC_OSC Trans Control Output State Control of Torque Converter
    TFT 96 ?C Transmission Fluid Temperature
    TFTV 0.53 V Transmission Fluid Temperature
    TFT_F No Fault Transmission Fluid Temperature Status
    TIRESIZE 683 1/min Tire Size (rev / mile)
    TOTAL_DIST 96583.0 km Total Vehicle Distance
    TRANS_VOLT_A On Transmission Supply Voltage Control State
    TRAN_RAT 3.424 :1 Gear Ratio Measured
    TRO_N_F Off Neutral Output Status
    TRO_P_F Off Park Output Status
    TR_A_DC 58.53 % Transmission Range Sensor Input A Duty Cycle
    TR_CORRECTED Drive/OverDrive Transmission Range Sensor Position - Corrected
    TR_CRANK No Transmission Range Input Allowing Engine Start
    TR_CRANK_F No Fault Park/Neutral Starter Enable Output Fault Detected
    TR_F No Fault Transmission Range status
    TR_FREQ 126 Hz Transmission range
    TSS 930 1/min Turbine Shaft Speed
    TSS_F No Fault Turbine Shaft Speed Reliable
    VPWR 12.99 V Control Module Voltage
    VSOUT_F No Fault Vehicle Speed Output Status
    VSS 10.0 km/h Vehicle Speed
    VSS 9.0 km/h Vehicle Speed
    WARM_UPS 3 Number Of Warm-ups Since DTCs Cleared20240502_173350.pngScreenshot 2024-05-03 195452.jpg
