as the title says ive got some WOT issues. truck is a '14 ram 1500 5.7 with the 8hp70 transmission. installed a TSP stage 2 NA cam and set of ARH 1 3/4 LTH. had some initial issues getting the truck to run and stay running, found some good info that helped out here on the forum and figured id ask some questions. when going full throttle i am not entering power enrichment. my wide band is showing between 14.5-16 AFR but nowhere near what i have set up in my PE tables, along with that my command EQ ratio in the VCM scanner isnt tracking either not sure if its supposed to stay at 1 the whole time.. the truck is being tuned using S/D tables, ive attached my current tune along with my last data log file. any help would be greatly appreciated.
2014 Ram 1500 5.7 WOTwith transmission VE tables smoothed .hpt
2014 ram 1500WOT4 .hpl
