Results 1 to 7 of 7
Thread: Engine too rich at WOT
    Nov 2016
    Austria/Europe
    46
    Hallo, I?m rather new in tuning and until now I didn?t work with the VE tables. I did a little bit with powerenrichment. Mit AFR at WOT from 4000 rpm up is about 10. Is it enough if I lower power enrichment, or should I work on the VE tables? I watched this on youtube https://www.youtube.com/watch?v=G7QGHuAYy48, but I think I don?t have enough data, or may I fill up all the rest?
    BTW I?m not able to upload attachment in google chrome, always have to change to Edge, is that normal?
    300C, 5.7, AWD, 2005. now 6.1 Block, 428 Stroker Kit, Thitek Heads, Procharger D-1S, American Headers Longtube, Fox Catback, extra Oilcoolers, H&R thread chassis, Pedders Bushings, Pedders Sway Bar front, Speedlogix Front Strut Tower Brace+Matrix Brace Subframe Connectors, 245/40 20 Tires, Movit Breaks, 370x35 6 Pistons Front, 345x32 4 Pistons Rear
    5BA8
    3,501
    What wideband are you using? The narrowbands don't look like it's 10:1 AFR. If it's that rich they should be almost a full volt, about .1 higher than they are now.
    email=[email protected]
    Nov 2016
    Austria/Europe
    46
    I?m using zeitronix ZT3 with a Bosch sensor, erverything else fine in my log? Trying to go to the Dyno this week and check wideband on both sides.
    5BA8
    3,501
    Quote Originally Posted by 123gr View Post
    Fuel trims are off pretty bad around 2000 rpm. They're showing +17% or so. That could be dialed in closer.
    Nov 2016
    Austria/Europe
    46
    Thank?s, I think I can?t do this by my self. PurpleRam helped me some weeks ago, but now he doesn?t reply any more.
    5BA8
    3,501
    I can help you out but I do this for a living. I can be contacted directly through my email in my sig.
    PS I've been to Austria a few times. Austria and Germany as well.
    Apr 2024
    Telford PA
    13
    PurpleRam is off playing with Team Aston Martian.
    Gonzo= 14 Ram 4x2 441Ci 9:90s on pump 93
    Lazy boy= 12 Ram 4x2 362Ci 11:80s on pump 93
    The Bee= 04 Rumble Bee 4x2 370ci 10:60s on pump 93
