Thread: 2017 RAM 1500 5.7 MDS Licenses
    Mar 2006
    Regina, Saskatchewan
    141
    Hello Everyone,
    I posted this question in the Dodge Gas area of forum, but another member suggested to ask the question in this area.
    Im trying to do a MDS disable on a 2017 RAM i did a Stock Read of PCM and TCM.
    When I opened the file after read it made me Agree and licensed the PCM.
    Once i modify MDS setting i goto write the truck it says im not licensed for the vehicle. It shows the serial number of the TCM at that stage.
    It shows i only need 2 credits to tune this make / model.
    Should i do a full stock read of just PCM instead of to prevent this?
    Just looking for some recommendations.
    Chris.
    Chris T.
    2014 F350 6.7 Powerstroke.
    2008 Ford F350 Super Duty 6.4L 72MM turbo
    2007 Escalade 6.2L
    2007 Yukon Denal 6.2L
    2010 Lexus RX350 3.5L
    2001 Tacoma 3.4
    2000 Camaro SS LS1 M6 - STS Turbo
    1998 Dodge Cummins 12v 5spd
    1998 Topkick Cat 3126E 7.2L
    1983 Toyota Pickup
    1982 Toyota Pickup
    2006 DRZ400
    2008 Turbo Nytro
    2010 Skidoo XP 800
    1978 Corvette
    28,273
    If you only want to tune the ecm you'll need to read just the ecm. Don't read the ecm and tcm.
    The ZF8 TCM requires additional credits as outlined on our supported vehicle page.
    Mar 2006
    141
    Perfect thank you I did that and it worked.
    Feb 2022
    CHILE
    When it comes to MDS disable on a 2017 RAM, the licensing process can sometimes be a bit tricky. Doing a full stock read of just the PCM might indeed help avoid this problem. It's worth a shot! Other folks might have different experiences, but that's what worked for me in a similar situation.
