Hi all, I have a hybrid Gen3-4 car that Im having monster troubles getting to run properly. I am by no means a tuner and I am pretty stupid actually, as I bought this car is a great example. So my knowledge of Hp and tuning is rudimentary, so be gentle.
Stumbles at around 2-3k rpms and looks lean? I have a AEM wideband installed, but it keeps failing. Got yet another on order.
2002 C5 Z06 Corvette
Here are the specs on car:
? GM crate LS3 stock engine ? with GM LS2 silver blade throttle body.
? LG 1-7/8? long tube headers, no Cats, only 2 forward AC Delco O2 sensors
? Vararam Intake, with Gen 4 MAF card type sensor
? 525cc FIC injectors.
? Racetronix upgraded fuel pump harness. 70psi at idle.
? LS3 coil packs
? Manual Transmission
? Gen 3 2003 engine wiring harness and 2002 PCM with Racetronix adapters for MAP sensors, throttle body, cam and crank position sensors and knock sensors.
? (8) Fuel injection adapters to use the Gen 3 engine wiring harness. LS6 knock sensors.
? Autoblip installed.
? Lingenfelter trg-002 58x-24x box installed on firewall.
? 18Lb lightweight flywheel
? 93 octane fuel, no additives.
? OEM fuel pump
? No emissions, No A/C, No ABS, No traction control or stabilitrac
? 10% ATI underdrive crankshaft pulley
