Results 1 to 3 of 3
Thread: 2023 ZL1 Driving mode change default...
    Dec 2022
    27
    Is there a way on a 6th Gen 2023 Camaro ZL1 automatic, can the default driving mode be changed via HP tuners. I want the car to start up in Track mode, and then only change when I press the mode select button? I figured copy the table lines from the order they are in, but that would still show the wrong "mode" to the edited settings, so that might be a bit confusing.
    1,472
    Are you talking about the suspension in addition to the motor/transmission settings?
    Dec 2023
    15
    I have a 2021 SS 1LE its the same platform minus the S/C and on my center screen I go to settings/vehicle/driving modes and u can choose to keep your npp in track all the time also your magna ride and steering u can soften or firm there,not sure if you already knew that or not hope it helps
