Results 1 to 5 of 5
Thread: Another Unlicensed Vehicle Issue
    Apr 2024
    3
    I have opened Ticket #421139 with support but they have been slow to respond. When trying to write my first tune revision on my HP unlocked PCM I am getting the unlicensed vehicle message. Under the licensing tab it shows that I am licensed for the vehicle. I have tried deleting the license file and resyncing and trying to write the tune with the beta version of VCM Editor with no luck. What am I missing?
    Did sending my stock file from my factory PCM to my tuner and not the stock file from the unlocked PCM create this issue?
    Mar 2021
    Pompano Beach FL
    267
    It could be the issue if the calibration has changed.
    www.n2speed.com
    http://www.amp4x4.com
    [email protected]
    Dodge And GM Tuning Suppport
    Diablosport CMR | HP Tuners
    28,292
    I took a look at your ticket.
    You read out the ZF8 TCM which costs 4 credit in order to license. If you do not wish to tune the TCM, please re-read your PCM only. You can do this by opening VCM Editor and going to Flash -> Read Vehicle. When the Vehicle Reader window appears, press "Gather Info" first, do not just press "Read". You will see both a box for "GPEC2A, 2015+" and a box for "ZF8HP" in the window now. In the box that says "ZF8HP" you should see a drop-down that says "Read Calibration". Change this drop down for the ZF8HP to "Do Not Read" and then press the read button at the bottom of the window. This will cause the software to read the PCM only, you can then make the changes to the PCM only file and you will be able to write it without issues.
    This is also covered in our Dodge Transmission section sticky https://www.hptuners.com/forum/showt...Suite-3-5-Beta
    Apr 2024
    3
    I followed your instructions but I still had to license the TCM in order to write my tune to the vehicle.
    28,292
    If you followed my instructions you would've only read the ecm and would not have to license anything other than the ecm. To me it sounds like you didn't follow my instructions.
