Results 1 to 10 of 10
Thread: C6 getting too hot?
    Tuner Alex14SS's Avatar
    Aug 2021
    Florida
    90
    C6 getting too hot?
    So I just tuned a manual c6 and after cranking up the fans to 92% all the way, it?s not cooling it but rather getting hotter? Could this be something mechanical? Or the tune messing with the thermostat?
    1,528
    How hot is hot? Are fans actually cutting on? When is it getting hot, idle or highway?
    No way the tune can affect the thermostat.
    Aug 2021
    Florida
    90
    It’s on idle after cranking them up.. very weird.
    5BA8
    3,394
    Almost as weird as this thread.
    email=[email protected]
    Mar 2009
    Andover, MN
    485
    It?s on idle after cranking them up.. very weird.
    Lets start with wtf does that mean. Whats on idle? The engine? Cranking them up. The fans? Your not spinning them faster? Just adjusting the ECT vs DC? Also, there is no log or tune posted
    Jul 2020
    VIC Australia
    1,171
    It's the tune messing with the thermostat. Need that fixed pronto. Adjust a/c pressure at 11.2% fixed it for me. Good luck
    3
    Can you elaborate on this? What did you adjust exactly? I have a similar issue of engine coolant temp slowly creeping up past 220+ only during idle.
    2008 Corvette Auto, Texas Speed Cam 229/242 115, Speed Engineering LT's and exhaust
    Jul 2020
    VIC Australia
    1,171
    Have you got a log of it getting hot? Would need fan speed, fan 1 on/off, fan 2 on/off, ect, ac pressure, ac clutch on/off, baro, plus your normal channels. And what the ambient temp is. Stock setup? Radiator fins clean and not bent? Coolant happy? No big assed aftermarket coolers in front of the radiator? Pictures of your setup if aftermarket would be good. If stock, no need for pics.
    1,528
    Not sure if a language thing, but typically in the US, thermostat means the mechanical device that opens and closes to control water flow and not connected to the tune.
    Jul 2020
    VIC Australia
    1,171
    Lol, correct. I was taking a swipe at the op for a terrible post. But the toilet water does spin backwards here in Australia . God damn millimeters were working out good and dandy until you lot started using mils. WTF lol
