Results 21 to 40 of 52
Thread: Kong 2650 with 112mm TB power reduction mode at 3200 rpm
  1. #21
    Mar 2024
    22
    Try setting MAX throttle to 90% ECM 3220
    I didn't see MAP logged. GEN 4 ECM's shut down at 255kpa. Heads up because I had two Kongs brought to me in the past year pullied over that and both cars hit a hard shut down when they saw 255kPa.
    Alvin, I spoke to someone at your shop and I ordered the AEM OBDII wideband. Once it's installed, I'll contact you for remote tuning.
  2. #22
    Nov 2006
    2,757
    Thank you very much.
    Tuner at PCMofnc.com
  3. #23
    Mar 2024
    22
    ETC scalar set to 8100 max throttle set to 90 %, AEM x series wideband installed, will log tomorrow.
  4. #24
    Mar 2024
    22
    When ETC area scalar was set to 8100 truck hesitated to stay on and died multiple times, set it back to 5636 and drove better. Added AEM x series wideband and MAP channel. Left max throttle at 90%. Im throwing in the towel.
  5. #25
    Aug 2006
    5BA8
    3,323
    When you increase the scalar you need to then add to your BRAF table.
    EFI specialist
    email=[email protected]
  6. #26
    Nov 2006
    2,757
    are you sure the throttle body isn't made by NW? He said he does them or did them at least for KONG.
    If it is.. the scalar should be left stock.
  7. #27
    Aug 2006
    5BA8
    3,323
    ^^^ Either way, I don't think the scalar or the P2101 settings have anything to do with the code he's getting.
    EFI specialist
  8. #28
    Nov 2006
    2,757
    The new NW style throttle body needs the max throttle limited on OEM silverblade applications or else it will throw 2101 and another i can't seem to remember right now.
  9. #29
    Aug 2006
    5BA8
    3,323
    Yeah, I can understand the P2101 settings to keep from going into REP from a P2101 but he has some other wonky code I don't think I've ever seen. P2167 Idle not learned.
    EFI specialist
  10. #30
    Nov 2017
    1,502
    The P2167 probably should be checked to the correct service manual, at least the description. An internet search returns that as "P2167 Throttle/Pedal Position Sensor E Maximum Stop Performance".
  11. #31
    Aug 2006
    5BA8
    3,323
    Agreed. Same as you should do with most codes, especially the odd ball ones that don't routinely pop up during tuning.
    EFI specialist
  12. #32
    Nov 2006
    2,757
    yeah.. That's why it sounded to me like it was opening too far.. common for a new NW throttle body on silver blade application. Maybe try 85%
  13. #33
    Mar 2024
    22
    I messaged Kong about who makes their TB, I'll make the adjustment on max throttle to 85% and log it again.
  14. #34
    Mar 2024
    22
    I got an email back from Nick Williams, and he said P2167 is a pedal code to check wiring and/or replace pedal. Pedal ordered will be delivered tomorrow.
  15. #35
    Tuning Addict
    Jan 2015
    6,825
    Might want to ask him how to set that tb up too. I thought Nick was only using the stock settings on the 103. Didn't know he started doing that on all of them. Airflow will change a lot with the opening throttle on that one. Your throttle was way under pedal. It shouldn't be like that, but it's possible a bad pedal sensor will skew the ecms inputs.
    ~Greg Huggins~
  16. #36
    Mar 2024
    22
    Per Nick Wiliams
    " start with stock ETC scalar, it may need to go lower. WOT should be limited to 95% with a 2008 corvette E38 PCM.
    Stock ETC scalar 5636.
  17. #37
    Aug 2006
    5BA8
    3,323
    Quote Originally Posted by LSAC10 View Post
    Per Nick Wiliams
    I fat fingered. Didn't even mean to quote this post ^^^^
    I meant to quote Greg. I think that condition you're speaking of was the result of the scalar being set at 8100. Just my opinion. Your thoughts?
    EFI specialist
  18. #38
    Tuning Addict
    Jan 2015
    6,825
    I thought it was using the stock scaler at that point, but if it was 8100 I could see the pedal being over throttle knowing how Nick set the tb up now, just perhaps not that much. I was thinking the false inputs from pedal might be throwing it off or the etc scaler being quite a bit too big or I guess in this case possibly even both combined. I just know once they get too far apart it'll throw it into REP and this one was starting to show problems around 30% pedal if I'm remembering correctly.
    Personally I don't agree with making the tb's mechanically work with stock scalers or use smaller than stock scalers. Guess it would be more safe that way, since it's technically lazier and not overly aggressive granted the tb motor has the capability of really holding things in place.... Don't know. Guess as a whole or big picture it's better, but personally I believe in having all of the throttle and airflow models set correctly instead of having a component work around the tune.
    ~Greg Huggins~
  19. #39
    Nov 2006
    2,757
    The new NW throttle bodies are throated to flow like a stock throttle body until a certain point. The throat and where the blade sits works like a cable throttle body bell crank. This means the throttle body is much more consistent and reliable at low throttle angles. This is a superior design. It's not a lazier way to do things.. its is a OEM way of doing things. And its why his throttle bodies can go on with no fuss.
    A straight bore throttle body.. or even a stock one that is ported does not behaive like this. So say at 5% blade opening vs 6% there is a HUGE difference in flow. This causes inconsistent behavior.
    As I understand it.. there is a table in the ECM that characterizes blade position with airflow. Looks like a MAF table. The scalar is just a global adjustment to that entire table. Not the low blade positions we would need to edit to make up for a throttle body without a proper throat. The scalar doesn't just trim idle. It makes the whole throttle range more or less sensitive?
  20. #40
    Nov 2006
    2,757
    I initially read it as a TPS throttle body too high code. It is a pedal code. this should take care of it.. or at the very least it isn't a TB problem. It could be still wiring or incomparable pedal with the ECM's OS. It's best to use the same pedal that the oem application did with the tune file you are using.. So 08 Corvette should use a 08 corvette pedal.
