Results 1 to 7 of 7
Thread: Please help adjust the fans of the Yukon 2007 car for those with experience
    Mar 2024
    4
    Hello
    I AM A BEGINNER IN AUTOMOTIVE PROGRAMMING WHEN I TRY TO ADJUST YUKON 2007 FANS USING HP TUNERS
    I don't see settings to adjust the speed of the fans
    I hope who has the experience to help me solve this problem
    The image is placed in the attachments
    and thank you
    1,532
    That vehicle probably doesn't have fan speed other than using two fans in series for low (6v per fan) or in parallel for high. What are you actually trying to accomplish?
    Mar 2024
    4
    Hello
    I'm trying to set the fans to work ahead of time so that the temperature doesn't rise
    And thank you for the quick reply
    1,532
    THe way I think it works on this one is you set the (desired % vs ECT) for a higher percentage at a lower temperature. This will then be used by (State vs Desired %) which will then be used by (Output control vs State.). If you put in 100% at the temp you want the fans full speed in the first table, I think that will accomplish what you want it to. It's hard for me to say for sure without seeing all of the settings in those tables.
    Mar 2024
    4
    Hello
    I uploaded table images
    Can I modify the settings from here to get a lower temperature
    1,532
    Missing the (Output control vs State.) table. But just try putting 97 in at whatever temp and up you want the fan to cut on full speed.
    Mar 2024
    4
    Thank you very much
    I will try and if I face any difficulties I will contact you
    Thanks my friend again
