Results 1 to 3 of 3
Thread: 2017 S550 Mustang 5.0 twin turbo tune question
    Dec 2018
    Hello guys,
    I've been trying to tune this mustang, it's my first s550 turbocharged. I've been reading a lot of posts inside the forum, they have been a big help, but I need new eyes on this.
    So far the car idles and I can drive it on the dyno, but when I hit the pedal the tb only goes to 50% opening. I'm attaching the tune file and log. Thank you in advance for your help!
    On3 twin turbo kit
    Return type fuel system
    ID 1050s injectors03152024,f new flash TTurbo.hptTTurbo log 7 new flash.hpl
    Sep 2022
    Clearwater FL
    210
    Driver demand is stock, Torque tables/inverse tables are skuffed. SD needs work. You still have the IMRCs? I would probably lock them open and simplify your tune that way. Search for a Roush tune on here it will give you a good idea on what everything should look like. You're building boost then hitting a torque request limit because your torque tables are still somewhat stock. Changing the axis numbers isn't good enough. Need to actually change the torque numbers...
    Advanced Tuner small tuner's Avatar
    Nov 2015
    271
    You need a good base tune to start
    Turbocharged COYOTE
    PM for E tune / Remote Tuning
    [email protected]
