Results 1 to 7 of 7
Thread: 6.4 charger 2013 cam tune
    hi
    i need advice and help for tune camshaft in 6.4
    this first time for me for tune camshaft in dodge car
    cat mods:
    headers 1 7/8
    afe cai
    cammption titan 1
    GRIND# XA221/365-XA227/365-14+4
    Hydraulic Roller Camshaft
    Performance
    Duration at .050": 221/227
    114 Lobe Separation Angle
    110 Intake Centerline
    Lift with 1.65 Rocker Arm Ratio: .602"/.602"
    VVt phaser lock
    spring high lift
    2 octan.hpt idle titan camshaft.hpl
    Jun 2021
    19
    disable neural network, tune VE tables, disable the VVT, little more spark at idle, log pressure ratio, and get a wideband to calibrate VE tables at WOT
    Quote Originally Posted by JohnnyFW View Post
    Please can you give me advance how we can disable VVT ?
    Jun 2021
    19
    post your stock file
    Sorry
    I am not have stock file for same car but i have for another car
    but i post stock for same car i was compare from stock another car
    Jun 2021
    19
    Here i made a base file and go from there dial in ve there are videos on youtube how to i would not go wot until you dial in normal cruising and get a wideband
    Brother
    Thank you very much car run great now
