Results 1 to 2 of 2
Thread: Clunky 5-3 Downshift 6l80
    Mar 2024
    So I'm very new to tuning and thought I'd give it a shot on my supercharged Hummer H2's 6l80. Mainly just trying to mitigate some of the clunkyness and make it last longer. I had a trans go out at 30k, one go out with 70k, and this one's got 40k on it. Figured I couldn't make it worse. The only things I've changed so far is the torque converter minimum slip so it stays locked up when cruising, and I adjusted the part throttle shift scheduling to make it feel like less of a turd.
    The issue I'm trying to resolve now is a clunky 5-3 downshift. Part throttle and wot. It's always been that way. Surprisingly the 6-3 downshift is smooth as butter. Slow, but it doesn't make you need a chiropractor like the 5-3 shift. It legitimately feels like running over a landmine. It's my understanding with the design of the trans that the 6-3 is supposed to be clunky not the 5-3 as it doesn't have to disengage the 4-5-6 clutch right? How can I smooth this out?(2) BC WOT and Part throttle shift mph normal only.hpt
    Also, let me know if the attachment works. This is my first post.
    Aug 2023
    SoCal
    452
    None of the kickdown or coast downshifts are supposed to be clunky, I would take it back to the company that rebuilt it and have them fix it instead of trying to Band-Aid it with programming. Also I know it's too late now but if it ever has to come back out again, do yourself a favor, and install our 6l80-TOW&PRO Reprogramming Kit™ in there and your problems will go away permanently and it will drive so much better.
    Robert Moreau
    TransGo
