Results 1 to 12 of 12
Thread: knock retard
    Jun 2021
    32
    Question knock retard
    My project 1979 Cutlass, LS swapped 5.3 (LM7) with Texas Speed cam stage 2 w/ LS6 valve springs. How can I go about addressing knock retard. I'm having knock in 4,000 - 4,400 rpm range. I have files attached. any help would be deeply appreciated, I've been trying to address this issue for some time now. If there's any other areas that needs attention, I'm open to any suggested adjustments.
    Arizona
    489
    Quote Originally Posted by Undre75 View Post
    I've been trying to address this issue for some time now..
    have you pulled timing in those areas?
    5BA8
    3,440
    4k-4,4k is your peak torque peak cylinder pressure range. You have too much timing in it at WOT unless it's a low compression motor. I'd pull 2-3 degrees from about half the table. See if that doesn't fix it.
    email=[email protected]
    Jun 2021
    32
    no, I haven't
    Jun 2021
    32
    ok and I'll let you know. I appreciate your time and input
    2,840
    This looks more like it has a pending knock sensor code. You can tell because anytime it gets into PE the knock sensors max out with max allowable retard. If you read the service manual it says this happens when a code for the knock sensors is pending or active.
    You have a lot of tuning left to do. This thing is very lean for most of the drive.
    Tuner at PCMofnc.com
    Jun 2021
    32
    wow can I get a start point!
    Jun 2021
    32
    I'm so frustrated with it because I'm far from a tuner. What would it cost to have it tuned via mail to correct my issues
    2,840
    Scan for the code. It will likely be like p0327. Then follow the service manual to correct it.
    Yes we do email tuning but a knock sensor code isn't a tune issue.
    Jun 2021
    32
    I did a scan and the code is 0x10: P0332 - Knock Sensor 2 Circuit Low (Bank 2) (Pending, Current)
    2,840
    Ok.. You should follow the service manual to address the problem causing that code.
    Until then your knock sensors are going to just pull max allowable timing anytime you are in PE (like heavy load situations)
    Jun 2021
    32
    thanks a lot, after I address the knock sensor issue are you open to doing a nice tune for me via email
