Results 1 to 11 of 11
Thread: Help tuning a 2017 6.0 Silverado 2500
    Aug 2023
    Nevada
    27
    First time trying to tune a gasser with HPT, got a 2017 2500 Silverado with the 6.0 engine. Was wondering where I should start for adding power and also the trans side. Vehicle will tow mostly. Thanks a bunch.
    Aug 2023
    Nevada
    27
    This is the file I read. Comparing it to a stock file from the repository, it has some differences.
    13,576
    You can make it more responsive but there isn't any real magic horsepower to be gained, nothing you are going to notice for towing anyway. You need to actually mod the engine, like different camshaft or add a supercharger if you want more grunt for towing.
    Your file from a repository file can always show minor differences depending on what version of the calibration it is, some trucks could be earlier built or later built with different calibration changes because of that.
    I can't edit your tune but I'm sure others will maybe be willing to help.
    Aug 2023
    Nevada
    27
    Would I edit the torque demand tables to make it more responsive?
    2,800
    The 6.0 Gen 5 stuff actually picks up a ton with tuning.
    They often have exceptionally long PE timers, the MAF is often way out of calibration at higher loads, and timing of course.
    This one looks like it was modified already, but could be done a lot better.
    Tuner at PCMofnc.com
    Aug 2023
    Nevada
    27
    Ok, made some adjustments to trans and PE tables. As far as timing, what is the data read as, BTDC?
    Aug 2023
    Nevada
    27
    Question about the maf, which way is it out of calibration? The intake is stock. With gassers, re-scaling the maf will either add or subtract fuel? This is how it works on the diesel side but how will that equate to more power for a gasser? I'm assuming they run a bit rich from factory at high loads so you want to lean it out a bit?
    2,800
    They are typically very lean. like 15%+ with the stock airbox even. SO add. But you should be measuring yours and tuning around what your truck is doing.
    They feel like they pick up 50 rwhp with a tune. Not saying yours will.. They are not common compared to the 5.3's and 6.2's but the few I've done have really woken up.
    Pretty surprisingly poor OEM tunes in them.
    Aug 2023
    Nevada
    27
    Thanks! Appreciate it.
    Mar 2022
    Indiana
    2,972
    Something I'll add.
    For a tow rig I like to get rid of that big spike in the VCT angle tables.
    Compensate for the changes at VCP spark. This can be done in either the VCP table itself or the base spark. In the VCP table, copy-with-axis 3400rpm and up then paste-add into the Low Octane table. Interpolate the columns between the horizontal bounds. See the trends?
    Do the same for Hi (watch MBT!). Afterward, zero out the VCP table.
    Of course, verify changes through logging.
    Quick example attached:
    Aug 2023
    Nevada
    27
    Something I'll add.
    I see! Thanks will try this out. I noticed the factory maps have tons of spikes and could use a good smoothing out.
