Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
Thread: 2002 Chevy Camaro Z28 Tuning Help
    Mar 2022
    Indiana
    2,941
    I'll elaborate.
    DynAir is the final reported airflow value. It's called Dynamic because the airflow calculation is dynamically scaled between MAF and VE. The more change in TPS the more bias to VE.
    At the cursor there is a dip in rpm, and DynAir is much higher than MAF. What happened there is the bias increased toward VE. VE is reporting a great deal more airflow than MAF, so that's why DynAir increases. The high DynAir is commanding more fuel. The result is that the O2's show rich because of the extra fuel. Extra fuel is making the engine stumble.
    What to do is set Engine Diag>Airflow>MAF Fail Frequency High to 0Hz. >DTC>P0101-P0103 to MIL on First Error. This forces full time SD so that VE can be tuned. You will also want to go to Engine>Fuel>DFCO>Enable ECT to 248F so that VE can be mapped during decel. >Fuel>Power Enrich>Min MAP 85kPa to keep CL online for the majority of the VE table.
    Attached is how to set it up. I've included other optimizations like O2 voltage switchpoints set to 451mV during tuning (restore afterward), Injection Timing for the cam, Over/Underspeed spark, and a few others.
    Run a compare to see. Compare>Open Compare File then Compare>View Comparison Log.
    2,742
    2002-04 Z06 makes 405 HP with the same injectors. My own 99 F-body made 400RWHP with those 02 injectors and ran high 11s with a 224/228 cam shifting at 6500 rpm. They are rated at 28.7 and a little higher in the Vettes. While they are at their limit there they will work.
    Just to back this up.
    I made 497 rwhp with my personal Z06. NA with these injectors.
    Tuner at PCMofnc.com
    Mar 2024
    16
    I'll elaborate.
    Thank you very much, You've been incredibly helpful, hopefully I can get this thing all figured out.
    Mar 2024
    16
    I am currently try to tune my VE table, when the car is idling in P/N it seems to be doing fine but when I put the car in to gear and tries to die so I bumped up the idle and it seems to be a bit better but still is happening it seems to also not be as bad when up to operating temp.
    ReStartUp VE Tune7 32924_SD.hpt
    stops while in gear.hpl
    wanting to die.hpl
    Mar 2022
    Indiana
    2,941
    Looks like you had a decent idea of what to do with the VE table. Don't be afraid to set it where you think it needs to be.
  6. #26
    Mar 2024
    16
    Thank you I'm trying to learn as much as possible! Do you think my VE table is why it tries to die when i put it in gear?
  7. #27
    Mar 2022
    Indiana
    2,941
    It's not helping. Once fuel trims are closer start adjusting other things as needed.
