Results 1 to 8 of 8
Thread: 18 scat more sensitive in drive
    Feb 2024
    23
    ok i have a hellcat blower swap car, and running smooth boost, so when in drive there is a huge lag because boost comes in via tps, so partial throttle is super annoying, i want the car to downshift with much less throttle given, what steps should i take to adjust the shifting so its not so much throttle needed
    Aug 2021
    Indianapolis Area
    186
    Hello,
    Log Shift ID to see which one is being used. Once you know, you have the change the shift ID accordingly.
    Based on drive mode, you can change aggressiveness.
    Thanks.
    DodgeBoy.
    YouTube: https://www.youtube.com/@dodgeboy2785
    Email: [email protected]
    Feb 2024
    23
    ok i added shift id to my channel list, car is in sport mode all the time, so i should just drive and let it shift and see what it says for what area its in? what part in the tune is adjusted then?
    Aug 2021
    Indianapolis Area
    186
    shift schedule for RPM
    shift pressure for "firmness" / comfort / aggressiveness
    Feb 2024
    23
    Quote Originally Posted by DodgeBoy_8HP View Post
    so on th schedule part on downshifts, how would i adjust those to downshift faster with less pedal,, its just not clicking in my brain, like would i go up and shaft rpm or down ? errr thanks for the help
    Aug 2021
    Indianapolis Area
    186
    Increase the downshift value to increase downshift point. If pure coasting, adjust the first line (top line) of the table.
    Feb 2024
    23
    so if im in 8th gear and i want it to go to 7th and 6th quicker i would increase the rpm ?
    Aug 2021
    Indianapolis Area
    186
    yes.
    As a good reference, watch the YouTube video I posted sometime ago.
    Link: https://www.youtube.com/watch?v=pvmaW3YmmGw
