how do i go about setting up a gas mileage 'gauge' so to speak? i know i would have to set it up in the scanner, but what formula and sensors wouldi use?
http://www.hptuners.com/forum/showth...ht=gas+mileage
post 17 but the whole thread looks like a good read.
For LS1's
This is the MPG PID I figured out....or what appears to be correctOriginally Posted by Soundengineer
-Scott -
Sadly (for me) it is very close.Originally Posted by soundengineer
with mine I set up a histogram...that uses just the MPG PID...then over the length of the scan it will average the instantaneous values and come up with my average MPG
heres how I set it up...
-Scott -
is the injector flow rate you speak of like 42.5#/hr or would that convert to something?
im guessing my car is more similar to the ls2 set up since its the 2.0 eco. and its not exactly stock...
its a PID you can log on LS1's
its the actual calculated flow rate on ls1's....it changes with rpm and with MAP...its not a static vale on any vehicleOriginally Posted by TotheNthRPM
-Scott -
As always, you come up with some pretty intriguing formulas. As always, us V6's are missing some stuff (or it's not even available).
In this case, my car does not have injector flow rate. Is there something that i could use in its place? Is there some way to determine injector flow rate with a formula?
Thanks,
Tim
