Thread: Jtec map decel table wut
    What does this table do? I think it's causing my iac control issues with my iac staying open and not closing down coming down to a very well
    I have a two bar map sensor so keep in mind the kpa changes
    On this map sensir 66kpa is 0 vac
    After I go into boost it feels like the iac stays open and doesn't close down right until like a cold start or just randomly....
    2000 Dakota R/T
    gt45
    42lb
    honda map
    10psi
    I changed the max allowed iac steps I cut it in half and the issue seems better
    2000 Dakota R/T
    gt45
    42lb
    honda map
    10psi
    Jul 2012
    Colorado Springs, CO
    42
    the throttle follower tables under Idle/Airflow influence how the IAC stays open after throttle. I have had the best luck playing with decay(rpm) if IAC stays open too much.
    Quote Originally Posted by joefus25 View Post
    what adjustments do you think i should make?
    basically after boost it just stays at the open position and changes all the light throttle tuning
    2000 Dakota R/T
    gt45
    42lb
    honda map
    10psi
