Results 1 to 20 of 20
Thread: Turbo hummer h2 build throttle imput issue.
    Mar 2024
    8
    Looking for help on my hummer h2 build.
    specs
    stock engine 6.0
    speed density cobalt ss sensor and ait sensor
    deka 60lbs injectors
    7865 turbo
    runs and idles great when warm and stabilized. cold start could be smoother.
    the main issue I'm having is with any throttle input engine cuts off and dies. if i stab it quickly it will rev up smother and sounds fine.
    here is the log and map file hoping i messed up somewhere on the base map.
    thank you
    5BA8
    3,253
    Map sensor and/or offset and linear are wrong. It's reading 200 Kpa key on engine off.
    What is the part number and where did you get it?
    Edit: the sensor you have in it is 1 bar.
    email=[email protected]
    Mar 2024
    8
    Delphi MAP Sensor PS10000
    was told was ok. this is a idle read not a ignition on read i can get a read of that if needed with logging it just ignition on
    i was told its a 2 or 2.5
    1,466
    Do a search on here for the PS10000 number and it will show that as a 1 bar. In the Supercharged Cobalt, it probably would cross reference to the Barometric sensor, not the MAP sensor.
    5BA8
    3,253
    You're logging 2 different map pids. One is buried at 105 Kpa and the other is reading 148 and the engine is struggling to idle at 400 RPM.
    Don't care what the sensor is supposed to be.
    Mar 2024
    8
    thank you ill try a trusted 2 Bar thank you
    Mar 2024
    8
    here is the new log with part number 19418808 2 bar same issue no changes here is the log.new log (1).hpl
    1,466
    Did you match up linear and offset for the new map sensor?
    1,466
    Never mind, that part number cross references to the same as PS10000.
    Mar 2024
    8
    so your saying its the same 1 Bar?
    1,466
    Yep, same thing I did.
    Mar 2024
    8
    Ya. I was having a hard time finding a true 2 bar sensor regardless of trying to find it by car. Cobalt ss map sensor was incorrect unless you buy the ac Delco which nobody has. Today I?ll get a pigtail and use a Duramax 4bar map sensor or a CTs-v 3 bar whatever I can find and I?ll update. Regardless I appreciate the help I would have over looked the 1 bar thing.
    5BA8
    3,253
    Quote Originally Posted by Evo8ben View Post
    Don't use whatever you can find. Get the right sensor for the application. So you don't have to cut/splice wires, possibly screw something up, etc.
    7,649
    The Cobalt SS MAP sensor is 1-bar. The Cobalt SS baro sensor is 2-bar. 12615136.
    1,466
    Is that for the Supercharged 2.0L SS or the 2.4L NA SS?
    7,649
    It's used on a bunch of different models from '04-'09 as the BARO sensor.
    Mar 2024
    8
    I upgraded to a 4bar map sensor and also tried a 3bar for testing we have the same issue. Any input in throttle vehicle wants to stall out. Almost as if it has no idea how much air is flowing in. But if I throttle rapidly on/off I?m able to rev to 5k no issues if I apply any amount at a steady rate it wants to stall
    7,649
    And did you set up the correct Linear & Offset for the various sensors you shotgunned at it? Were they pinned correct for each sensor (they are not all the same)?
    Mar 2024
    8
    Got it figured out with a zr1 3bar and the issue was with the maf sensor was set to be ignored so it was still trying to read maf. Once I allowed it to fail it worked great! 5psi rip today no issues.
