Results 1 to 2 of 2
Thread: Recommend Me Which Injectors To Buy Please!!!
    Jan 2024
    1
    About to turbo a lq4 2500hd truck to have something to play with because I?ve never used HPTuners before but have messed with other systems. Anyways, basic build (SBE,TruckNorris Cam, studs/ls9 gaskets, etc) cast 7875 turbo. Planning the fuel system, probably do 450 in tank(possible twin 450s) but I figured somewhere around 72-80 lb/hr injectors but there?s so much mixed opinions/info on injectors I don?t want to buy something I can?t tune. Please recommend me a set of injectors to buy so I can get this project rolling.
    It?s a budget build of course but I?ll spend the money up front if it saves in the long run. But once cry once is the best way, but brand name chasing isn?t a worry if that makes sense. If anyone has a link to a reliable place to buy or a member seller I?ll buy from them. Thanks in advance!!!
    Dec 2019
    MS
    568
    I use these in most turbo trucks unless its going to be running a Holley ECU or E85.
    https://fuelinjectorconnection.com/c...high-impedance
