Hello, I have swapped a "LS1/6" crate motor that I bought second hand from someone that had an unfinished project from 2016. It was from an older gentleman who did not have any documentation other than it was a "410 hp LS1/6". Block code is LS6/LSA, it has an LS1 manifold, flat top pistons, 706 heads for more compression, unknown cam (guy said LS6 but no proof) and shorty headers. It was new, still in the crate. I mated it with a 4l80e and have it in the car and running what seems like good. I have been reading and studying everywhere I can to learn more and try and get my tune closer. I have a Howell reprogramed ecu and harness that came with the motor that I used as a base tune. it started and idled first crank. It was a 5.3 truck tune that I added and segment swapped for the 4l80e, changed my motor size and volume, egr delete, fuel system etc. I was able to get my fuel trims under 5% with minimal MAF and VE tuning. I have a wideband and plan on spending some time to get the LTFT's under a percentage or two. I have not started to tune spark yet I noticed my advance seems super high compared to stock tunes. I only have 91 octane in my area so I will be bringing it back down a bit, but I am only getting a tiny bit of KR under full uphill acceleration.
Here is my current tune and a 20 mile driving log. How does it look? Any red flags?
it runs good but seems a bit low on power? I am starting to think I should have started with a stock ls1 or ls6 tune and gone from there as when I compare to those tunes I am different on almost every setting?
Should I continue honing in on perfecting this tune or should I start over with a tune that is closer matched to my engine?
