I'm pretty new to tuning but learn pretty fast I've been seeing huge swings in AFR, the colder it is the more rich it is. Obviously this makes it very difficult to dial in the ve table. I've been running around e50 to e70 but have had to run different stoich ratio to change with different temperatures. The truck has been doing this long before I started running ethanol. It makes it impossible to dial in the ve because it changes so much from day to day. IAT sensor is in the manifold. Stock engine, 7875 ,65 lb injectors walbro 450.
